How do I add a printer in Loyverse in order to print via WiFi?
PDuVille
Go to solution Solved by Celia,
Wifi printers usually work the same as Ethernet printers because in both cases the router is needed. The difference is that for Ethernet printers you need a cable in order to connect to router while for WiFi printer is not needed this cable. All the other requirements are the same as for Ethernet printer.
